In line fuse
Posted: 21 May 2008 00:29
by samco
Located by the fuse box there is an in line fuse with brown wires to it. Does anyone know where this fuse holder is supposed to live and what does it do
www.metronewquay.co.uk www.wheelintheheel.co.uk
Check out my album
1980 Californian import converted to right hand drive V8. Under construction.
Posted: 21 May 2008 06:35
by Rayjones
At a guess, could it be a fused live for the radio, perhaps a later addition!
Ray
1980 UK BRG 2L DHC
Posted: 21 May 2008 15:47
by Henk
It's the headlamp circuit breaker it's folded in or around the fusebox.
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Posted: 22 May 2008 07:32
by samco
It has a brown and purple wire to it which goes to the relay for the hazard warning lights.
Check out my album
Posted: 22 May 2008 09:22
by TR Tony
Well Lucas wiring did follow a code & as far as I can find out a brown wire with a purple tracer would be a direct unswitched but fused live supply from the battery.
However if it is a purple wire with a brown trace then it would be horn fuse to horn relay when horn is fused separately.
Brown with purple sounds more likely as I guess the hazard lights would have a direct live feed so that they could be activated any time.
