Steve @ SandS wrote: ... Tie wrapping them is a good "get you home" fix but isn't something that should be used long term.
John_C wrote: ... Having the TriumphTune Weber installation means I don't suffer from this particular problem but the carbs can still work loose about every thirty years and need to be tightened back up.
Monkeyzak wrote:I sealed them. The cars not moved and ones split already.
Beans wrote:Steve @ SandS wrote: ... Tie wrapping them is a good "get you home" fix but isn't something that should be used long term.
You're probably right there but in my case the "get you home" bodge lasted well over 7 years
Steve @ SandS wrote: ... Knowing you Theo I would suspect your "bodges" are better than most
Users browsing this forum: No registered users and 187 guests
