Cork rocker cover gasket
Posted: 22 Jun 2016 07:56
by UKPhilTR7
Is it advisable to put a little grease between the head and the cork rocker cover gasket, to help with the seal? I know it is not a good idea to put gasket sealant between the head and the gasket, but wondered if a small amount of grease was OK. Just to help the seal.
Re: Cork rocker cover gasket
Posted: 22 Jun 2016 08:03
by gr8
Personally I would get a silicone one.
They take a little more time to fit but once done you can remove the cover and refit without having to fit a new gasket.
Done this few times on our TR6!
Posted: 22 Jun 2016 13:43
I have always used graphite grease on anything I want to come off cleanly some time.
Posted: 22 Jun 2016 15:16
I sprayed the side of the gasket that goes against the valve cover with red tacky gasket spray. The head side is dry and clean as is the gasket side that contacts it. I do that with all gaskets. No leaks in 9 years. Being a spray you get an even coating on the gasket unlike having to spread a paste with your finger. As far as removing gasket never had to do one I've done yet but other gaskets I use a gasket remover spray.
Posted: 23 Jun 2016 00:05
by UKPhilTR7
Thanks for the replies guys, it gives me a bit of help for the job I have planned in my mind for this weekend. I did try the silicone ones, but had a hell of a game with both that I fitted. It will take a fair bit for me to go back to them now:
http://tr7triumph.com/forum/viewtopic.php?f=2&t=23156
