Wooden spit.
trv8
Wooden spit.
Postby trv8 » 25 Aug 2010 15:04
Been thinking of making a spit for when I start my new project.
Now as I don't like parting with my money [^], I'm thinking of doing this but a slightly modified and beefed up version......
Now, promise not to laugh, it should work. What do you think[?]
http://i258.photobucket.com/albums/hh25 ... ierear.jpg
seven
Postby seven » 25 Aug 2010 15:21
I would be more incline to ditch the wood and make the same pattern out of box section steel and 1/2 plate[:)]
I think the wood you are showing would have a tendency to break, more than likely when you are working on it.
regards
Pete
Postby FI Spyder » 25 Aug 2010 16:11
I have seen wooden rotisseries made out of wood 4x4. I believe the picture was on this forum. There are vagaries in wood so which ever route you go you would want to over engineer it. Personally I plan on making my own out of steel and my welder.
Postby windy one » 25 Aug 2010 18:32
wooden rotisseries <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
.... Im guessing this is what he meant by 'Spit'[?]
Ianftr8
Postby Ianftr8 » 25 Aug 2010 18:33
Where are you located? I have one not in use at the moment that I can be borrowed if you like.
Ian
Ian Freeman
1962 Triumph Courier
Postby nervousnewowner » 25 Aug 2010 19:24
new project???? what you up to now?[:p]
cozyheatdave
Postby cozyheatdave » 25 Aug 2010 19:36
Bunch of pictures added in the V6 part of this forum... Under "My White TR7 - V6 Project"
Go check it out!
mb4tim
Postby mb4tim » 25 Aug 2010 20:19
I used a wooden spit for my MGB. It worked great- thing was mounted for 10 long years - floor, sill, and battery box replacements done on it.
http://www.tgnagy.com/mgb/progressPages/199912.CFM
-Tim
trv8
Postby trv8 » 25 Aug 2010 22:42
Ian,
I'm in Cardiff [^]. I won't be starting for a while yet. But when I do and if it's still available, I'll be in touch. Thanks ever so much for the offer [:)].
Nervous,
Not sure, just playing around with a few ideas at the moment [}:)].
cozyheatdave,
Thanks for the photos and sizes. Nice one [;)].
mb4tim
Hope mine doesn't take ten long years [:(]. But, at least it proves wooden spits are strong and sturdy enough [:D]
Postby bmcecosse » 26 Aug 2010 12:45
I like it! Thicker section timber and a few more bolts - and really - it should be fine.
mb4tim
Postby mb4tim » 26 Aug 2010 19:19
what you don't see is a 24" 3/4 plywood disk on the front with hole drilled into as stops. You spin it to where you need it to be, push a bolt through, and it stays.
-Tim
Postby REPLIC8 » 26 Aug 2010 20:59
I think it depends weather you're a metal or wood type of person. I'm a carpenter so I'd quite happily build a wooden one. If built well it will hold the weight of a shell quite easily.
Last TR
Postby Last TR » 26 Aug 2010 22:45
Wood has been the material of choice for everything from ships to airplanes. And obviously, Marcos didn't see any problem with it.
http://www.rory.uk.com/marcos_wooden_chassis.htm
Ken
Anchorage, Alaska
Users browsing this forum: No registered users and 111 guests
