steering shaft
Posted: 03 Jul 2010 18:40
by pupinabox
How the heck do you get the steering shaft off? I would like to remove, I believe it is the intermediate shaft, between the steering rack and the firewall. Anybody got pic's?
[IMG=left]http://i160.photobucket.com/albums/t194/pupinabox/353.jpg[/IMG=left][IMG=right]http://i160.photobucket.com/albums/t194/pupinabox/tr7005.jpg?t=1271517043[/IMG=right]
Posted: 03 Jul 2010 19:46
by REPLIC8
Undo & remove the bolt in the upper coupling, undo & remove the bolt in the universal joint by the steering rack.Push the shaft back up towards the bulkhead so the universal joint comes of the rack & then pull it back down away from the steering column. [:D]
Posted: 03 Jul 2010 23:26
Opening up the gaps in the U-joints with a large screw driver and a few taps with a copper hammer might turn out to be usefull too ...
Posted: 04 Jul 2010 08:51
Edit ... forgot this one;
You'll have to remove ALL three bolts from the shaft.
Otherwise the U-joint at the top won't slide down far enough to get it of the steering column ...
