Feels like christmas all over again!
Bobbieslandy
Postby Bobbieslandy » 22 Mar 2010 14:24
This should tighten up the car no end, i wish parcels like this turned up every Monday morning! Hats off to RobSport for that one.
Deadline for sprint conversion 19th April, want it MOT'd and taxed by then too. No pressure! Once i'm back from Le-mans the spax will be replaced by something else, The advice against Spax proved true. the rears appear to have seized hence these temporary replacements.
Rob.
Postby Beans » 22 Mar 2010 15:59
Better get started ... [:D]
Postby PeterTR7V8 » 22 Mar 2010 17:15
Poly wolly doodle! [:D]
Ianftr8
Postby Ianftr8 » 22 Mar 2010 19:07
Hi Rob,
If you want a hand doing the front end don't be afraid to ask. I have done loads.
Ian
Ian Freeman
1962 Triumph Courier
Bobbieslandy
Postby Bobbieslandy » 22 Mar 2010 19:53
Hi Ian, Thanks for that. I should be ok, if it does all go a bit wrong i'll be taking you up on it! you're perfectly welcome to pop round for a cuppa though.
My only real concern is when it's time to start it up. The previous owners comment that "it was holding back and lacked power" is worrying me.
So far i found two cables which run from the luminition module with damaged insulation, the bare cores had been rubbing and shorting out on the dizzy housing, easy enough to sort, just hope it hasnt caused it any long term damage.
the second thing was a 2" crack on the tubular exhaust manifold where it bolts to the gear box, i've since welded it up (silver bit around the bracket, only had stainless filler rod)
and pulled out the worst of a section where it had obviously hit the ground, havent had a chance to grind the stud yet though.
I'm dreading what other horrors i'm going to find in the next few weeks!
Postby PeterTR7V8 » 22 Mar 2010 20:34
I did my ARB & sub-frame bushes last night. Took about 4 hours with no real brain teasers. The 2 tricks are the assembly order of the SF bushes which are different front to rear & using a spanish windlass (ratchet tie-downs) to pull the ARB ends together to get them in/out of the lower link eyes.
SF front bushes.
SF rear bushes.
Users browsing this forum: No registered users and 801 guests
