Gas tank is hard to fill
Posted: 07 Mar 2010 19:30
by Tom M.
The gas pump keeps clicking off as I try to fill the tank.
Has anybody seen this before?
Thanks,
Tom M.
Posted: 07 Mar 2010 19:38
Standard on all TR7's I have ...
Posted: 07 Mar 2010 19:47
by PeterTR7V8
I usually have to give it half trigger for a few seconds before the gas flows freely enough to use full trigger. After that it fills at full flow.
Posted: 07 Mar 2010 19:48
There's a fairly tight bend in the filler pipe.
High capacity petrol pumps don't help
Posted: 07 Mar 2010 21:49
Tom, are your tank breather, gas vapour separaror, charcoal
canister, & vacuum lines to your carbs all clear, to allow the air
out when filling?
Posted: 07 Mar 2010 21:50
by gaz
just back the pump nozzle of 1/4" so the end of the nozzle isn't touching the little bar that runs across the filler tube and all should be well but start slowly as mentioned before other wise you will get spattered
Posted: 07 Mar 2010 21:55
It could just be a US spec thing, too.
My 7 is as good as gold.
My ex US 8 has a different structure in the top of the filler neck,
& is a fair bit slower, & requires more care when filling.
Posted: 08 Mar 2010 02:48
I always fill with partial lever so I don't get any flashback with all my cars so don't have any problems. Some pumps are more sensitive than others.
Posted: 08 Mar 2010 12:01
by Tom M.
Thanks for the hints, I have some work to do!
Tom M.
