Gearchange lever
Gearchange lever
Postby nick » 08 Feb 2010 23:51
Here is an interesting field fix I found once I removed the gearchange gaiter. Whilst I know that some strange things came out of Triumph, like the gearbox mounting bolt ties, this surely did not come from the factory. I don't see this part in Rimmer's catalogue. Is there a flange that bolts this down or how does it attach?
[img][IMG]http://i615.photobucket.com/albums/tt234/nickmi/Gearbox%20mount/107_0719.jpg[/img][/img]
'79 TR7
Postby Workshop Help » 09 Feb 2010 00:23
This is the kind of back yard engineering some folks think is just plain brillant!
But, not me.
What happened back in the dark ages is the tab on the collar broke off. The tab was held in place with that bolt still in place. I suggest you seek an undamaged collar, or have a new tab welded onto the old collar. Also, check to see if the small spring and nylon button are present. If not, order a new one. This spring & button keep the shifter from rattling. It fits in a hole on the back side of the shifter and is held in place by the collar.
Postby nick » 09 Feb 2010 00:24
I found the part in Rimmer's but it is NLA. Looks like it is retained by a single bolt through a flange. Maybe the field fix is just as good. It has held up for at least 5 years.
'79 TR7
Postby Rich in Vancouver » 09 Feb 2010 01:46
It would be easy enough to make up a tab and weld it to the collar.
Ianftr8
Postby Ianftr8 » 09 Feb 2010 09:56
Robsport certainly had the collar part last year.
S & S list them today at £10.00
UKC 3159
Ian
Ian Freeman
1962 Triumph Courier
Postby nick » 10 Feb 2010 00:26
Thanks Ian. I have a pretty large order coming from S&S so I just emailed Rick to add the retaining cap.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ianftr8</i>
UKC 3159
Ian
Ian Freeman
'79 TR7
Users browsing this forum: No registered users and 120 guests
