FRUSTRATION TIME!!
FRUSTRATION TIME!!
Postby tr7inc » 30 Jan 2010 08:33
Hi guys, just wondered if any of you had come across a similar problem now i know its daft, but i seem to still have the ongoing problem with my bonnet not, lying as flush as it ought to do, now at first thought it might be the bonnet is warped somehow but i ruled that out when i had it off etc, but what i did find interesting is that, with the airscoop off it sits fine but with the sccop on it doesnt now forgive me for sounded daft here but any way round this part from removing the airscoop as it is in the correct place honest[:)].
Many thanks all
Postby busheytrader » 30 Jan 2010 08:57
Are the rubber seals fitted top and bottom new or the original items?
Sometimes the new stuff doesn't have the correct profile.
Postby tr7inc » 30 Jan 2010 13:04
Hi Adam, the seals that are on are original, although to be fair they could do with being replaced.
Postby nervousnewowner » 30 Jan 2010 14:49
borrow hammer from first pic on zoes respray of amber....
Postby windy one » 30 Jan 2010 15:26
By air scoop are you referring to the fresh air duct for fresh interior air?
Yes, Ive had this problem. Ny cure on my car was...put it in place being sure its in the lower channels. latch it with the two latches at the top. Unlatch slightly and push down on each side of the duct, then relatch. My problem was it would rise up on one side or the other as it was being latched in, hitting the hood.
Postby tr7inc » 30 Jan 2010 15:38
Yes Johnny, the fresh air scoup intake Many thanks for that i will get that one a try tomorrow, that might well cure the problem
Thanks again guys
Postby nick » 30 Jan 2010 16:45
There is a flange on the firewall at the very bottom that holds the intake in place. Be sure it is not bent and the intake can slide fully in and all the way down.
'79 TR7
Postby tr7inc » 30 Jan 2010 16:57
Many thanks Nick, i will double check tomorrow
Thanks again
Postby FI Spyder » 30 Jan 2010 18:21
When I replaced the rubber on the firewall and the rubber on the fresh air plenum I had to adjust the latch so it would close. It does sit up a little higher but that is something I'll have to live with until the rubber takes a set in however many years (it's three now) and I'll be able to adjust the latch down a little. Makes sense that with the rubber profile the way it is it's going to sit a little proud. With an all black car it isn't as noticeable as a yellow car.
Postby gaz » 30 Jan 2010 23:11
and there was i looking at your pic and thinking yeh it is high then i realised it was your sig. pic. and your bonnets not been shut for ages[:D]
Postby tr7inc » 31 Jan 2010 07:59
Hi Gaz very good, hope you are well and hopefully see you at biling this year.
Postby tr7inc » 31 Jan 2010 15:35
Well ive tried all i could today and it still sits up proud, so, i'll leavImagee it for now and come back with a fresh appraoch another day
Postby John Clancy » 31 Jan 2010 16:00
It takes a major effort to get that darned fresh air duct reinstalled correctly on my car every time I take it out so you're not alone with this one Steve. Mine seems to have terrible trouble seating into the guides mainly due to the throttle linkage used for the Webers but it's probably something similar causing your problem.
Postby tr7inc » 31 Jan 2010 16:31
Hi John, i couldnt agree more, sometimes it can be the smallest of things that can eat up youre time, but i keep saying to myself i will never give up, with it all, shes too precious too me, on day i will reap my rewards for my bruised knuckles and sore hands.
Postby FI Spyder » 31 Jan 2010 19:28
Try shutting the bonnet with the air plenum out to see if the rubber seals on firewall is holding it up. If it will lay flat then you know it's the air plenum. If you have to adjust the bonnet latch be careful not to adjust it too tight as it will be difficult to unlatch it. Little bit at a time.
It's harder to fit the plenum on a FI car as the throttle valve is right next to plenum and you can't really see what it's doing although the trouble I've had is missing the firewall clips so it doesn't sit flush to firewall (it would sit lower so that's not your situation).
Users browsing this forum: No registered users and 111 guests
