Ignition switch, which side should it be?
Bobbieslandy
Postby Bobbieslandy » 17 Jan 2010 19:25
Hi all,
My 1979 (registered in Dec) FHC has the ignition switch on the left hand side, the same as my defender. Was this right? a friend of mine has a 1980 DHC and his is on the right. Very strange.
tr7jim
Postby tr7jim » 17 Jan 2010 19:31
The lefthand side is correct, but suggest your car was built for a while before been sold. The vin number would be the best indicator to check it out.
Jim Johnson
Bobbieslandy
Postby Bobbieslandy » 17 Jan 2010 20:03
was there a reason for the change from left to right? i think having the indicators on the right hand stalk is a good idea, means i can change gear at the same time! Well i will be able to once she's back on the road.
Rob.
bottomtop
Postby bottomtop » 17 Jan 2010 21:06
Strange. Mine is on the right, and the indicator is on the left. Novemner 1979 Canley. This is in Australia (we drive on the left side). I've been thinking of changing the stalks over if possible.
Postby FI Spyder » 18 Jan 2010 01:35
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by bottomtop</i>
Indicator on the left with ignition on the right is LHD configuration. Sounds like factory got it mixed up on a few or the RHD conversion was not complete.
Postby Hasbeen » 18 Jan 2010 02:45
I have had 3 Oz delivered 7s, all 1980, & all ignition on right, &
indicators on left. As everything else is indicators on right, I
spend a fair bit of time turning the wipers OFF, when I wanted the
indicators.
It doesn't matter which car I'm driving, I can still get it wrong.
Thank god we don't have the same confusion with the brake.
Postby REPLIC8 » 18 Jan 2010 06:38
Late '79 cars can still have the ignition on the left & wipers on the right. It was a time of transition so you could have either depending on the build date. Some cars hung around for a while before they were registered. My 1980 TR7 was all original and had the ignition on the left.
[img][IMG]http://i473.photobucket.com/albums/rr92/REPLIC8-2008/int.jpg[/img][/img]
Postby Cobber » 18 Jan 2010 11:06
<font size="2"><font face="Comic Sans MS">I changed my indicators over from the left to the right and the wipers to the opposite. I got the NOS indicator and wiper stalks from "Auto Spares Galore" Burwood Hwy, Fern Tree Gully. The grumpy old bugger that runs the place wont bother to try to look the parts up so you'll need to take the old bits in and drop them on the counter so he can visually ID them and you'll need to explain that you want the opposite sided units.</font id="Comic Sans MS"></font id="size2">
85'Alfa 90, 69'Ford F250.
Users browsing this forum: No registered users and 89 guests
