I'm a bit puzzled here. As you know I'm working on dads TR7V8 and now I'm freshening up his front
struts... I found this strange phenomenon when I started to (trial-)fit everything back together:
On the shock absorber rod there is a ledge (actually there are two, but let's disregard the upper one
closest to the threaded part for now) arrowed in this photograph:
On this ledge the plastic (nylon or something) bushing UKC329 is riding/seating. Arrowed A in the
picture below. This means the second ledge on the rod ends up roughly 5 mm <u>above</u> the top
surface of UKC329, preventing the large flat washer UKC9395 to rest on the bearing surface of
the nylon bushing. This all seems wrong to me, shouldn't the rod ledge seat on the spring-seat
steel cup bottom, at the hole arrowed B? What's up with this? To me it seems I'm missing some-
thing important here, or is there really an intentional 5 millimetres of play to be built in here?
