I have been cleaning up the intake on a standard 2.0L TR7 with twin SU's.
In the following photo I show that funny plat on top of the manifold. One side of the gasket is silver as you see and the other is a normal fibrous type material.
1. Should I use some sort of gasket cement with this gasket? if yes then what type of cement should I buy?
2. Does the silver side face the manifold or the blanking plate?
Also, I have removed and then placed the carbs back onto the rubber isolators on the manifold. SHould I use some sort of cenment with the gaskets that go between the carbs and that Link Plate (TKC1718)
