WINDSCREEN WASHER PUMP QUESTION
Postby tr7inc » 02 Jan 2010 17:58
Hi all and happy new year to you all, can i ask a daft question here, just wondered where the correct postion is for the Windscreen washer pump to fit to, ive seen a few 7,s with themn in slightly different locations, and although it may be a daft question just thought id ask, as when i got m 7 the pump itself had ben removed and never refitted and i cant find any locating holes where i think it ought to go, any pics on this would be a great help.
Once gain many many thanks
Maki
Postby Maki » 02 Jan 2010 18:30
There should be two holes with captive nuts and rubber surrounds on the nearside bulkhead behind the battery.
Postby Beans » 02 Jan 2010 18:30
For a RHD car you'll have to mirror the picture [;)]
<b>http://tr7beans.blogspot.com/</b></i></center>
Postby tr7inc » 02 Jan 2010 18:38
Many many thanks Beans thats the pic i was hoping to see
Thanks again
Postby tr7inc » 03 Jan 2010 09:14
Hi all well i did manage to locate the holes that some bright spark had filled in, problem is the locating holes are there, but there dont seem to be anything for the screws to grab hold of behind the holes, any suggestions?
Many thnaks again
Postby saabfast » 03 Jan 2010 09:24
I think they might have been self tappers. Mine had rusted out around the screw so I opened the hole a little and used a plastic wall plug which was a tight fit, then put the self tapper into that.
Saab 9000 2.3 FPT Auto
Postby tr7inc » 03 Jan 2010 10:10
Thanks Alan, i will try that
Many thanks
Milanoverde
Postby Milanoverde » 03 Jan 2010 12:52
Originally , there were small plastic or mylon inserts pusdhed into the holes. The screws went into them.
Postby tr7inc » 03 Jan 2010 15:22
Just to let you know, i tryed the wall plus idea and hey presto...... it worked many many thanks
