80 tr7 just stopped running
dan18018
Postby dan18018 » 09 Oct 2009 17:26
was running perfect, shut off while running, definitly electrical,
replaced coil, amplifier, trying to find inline resistor, please help
tr7jim
Postby tr7jim » 09 Oct 2009 18:12
dan18018,
the inline resister is actual a wire which is steel stranded instaed of Copper, its white / pink line.
The 6v feed starts of white wire from the fuse holder then pop through into the engine bay just and then the White / pink wire then goes back into the loom and then final changes again to a white / grey line to the coil. You see the engine bay jointed wire on the coil side of the bulkhead with a black heat shrink sleeve on it.
Hope this helps.
Another common problem with the coil electrics is the feed from the coil to the Distributor uses a spade / female connection sometime is bare and shorts out to the engine or bulkhead so stopping your engine.
Hope this helps.
Jim Johnson
Jim
Users browsing this forum: No registered users and 59 guests
