<font size="2"><blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Marko</i>
anyone solved the problem?
like welding a patch of stainless steel inside ( is harder and stronger ) , greasing the pivot point with some copper based ( or ceramic based, something with crude lubricant inside) grease ?
or that "newer" fork that has those bends to unscrew the bolts behind it is better?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"></font id="size2">
The pivot pin wore through the clutch fork on mine (no evidence of any grease or lube on the interface) prompting my V8 conversion[:D] The clutch pedal went all the way down, came back up again and became solid.
When I rebuilt the clutch, a thick blob of copper grease was applied to the pivot pin and socket on the new clutch fork with the excess wiped away. I reckoned this would reduce the wear and hopefully not pick up too much friction plate dust. 18 years later and the clutch action is still smoother than the original, although it's covered far fewer miles since.
I've heard of others applying a bead of weld behind the pressing / socket of the clutch arm to give it extra strength although I reckoned a bit of lube was necessary to stop it wearing out in the first place.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes, Anti- Dive, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 5 Spokes and Cruise Lights. No Door Stickers. Mine since July 1986, V8 from 1991
