Hazards work, indicators don't
Posted: 25 Jun 2009 21:17
by John Wood
Any ideas please?
1975 FHC
KDU483N
Posted: 26 Jun 2009 00:45
Hazard and turn signals use different units. Turn signal unit may be faulty, bad connection in horn/turn/dip switch.
Posted: 26 Jun 2009 04:14
by jclay (RIP 2018)
Hazard flasher unit is by the fuse panel.
Indicator flasher is up under the dash on the door side.
Posted: 26 Jun 2009 06:48
by HowardB
The flasher unit has a reputation for flashing v slowly or not at all and is often replaced by an electronic flasher available from Halfords. The unit is the same size and only modification required is an additional earth connection.
Posted: 28 Jun 2009 13:54
by John Wood
There is no unit under the dash, just 2 loose connections.
1975 FHC
KDU483N
Posted: 28 Jun 2009 14:18
by John Wood
All sorted now
1975 FHC
KDU483N
Posted: 28 Jun 2009 15:08
by jclay (RIP 2018)
Kewl! Now you are a regular flasher!
Posted: 29 Jun 2009 20:10
by pupinabox
what did u do?
