Rimmer Discs ID Discovered
Chunk
Postby Chunk » 05 Nov 2007 22:04
36 dollars, i think that's about 18 UK pounds each.
Sounds like a bargain to me.
No worries
Phil
1979 TR7V8 FHC 3.9 Litre
19 years of tinkering and tuning...... So Far!
Laying down a rubber road to freedom.
Postby TR Tony » 06 Nov 2007 17:21
The Supra discs are £28.33 each from Brake Parts Online here in the UK. They also show the discs as 82-85 model year. 4 bolt fitting, diameter 258mm & thickness 20mm.
They also have the Vitesse 4 pot calipers at £73 each. So just over £200 for set of calipers & discs, just need those adaptors off Ebay & you have saved yourself one hell of a lot over Rimmers kit price of £405. To be fair to Rimmers though they do include pads, hoses & fittings, all of which you would have to buy separately.
Still, good to know what parts are involved.
Postby john 215 » 06 Nov 2007 22:15
Hi Tony,
The only problem is a standard Viteese caliper does not have a spacer fitted between the two halfs were as the one's in the kit do.As Phil and myself found out thats were they leak [V]
Cheers John.
letstorque
Postby letstorque » 09 Nov 2007 05:06
If you are getting discs, then make sure you ask for Celica Supra. They are the four Stud items. The later models dropped the Celica name and gained an extra stud. (or turned the owner into a Stud when they bought one. Never worked for me though. [:D] )
<b><font color="blue">Eunos Roadster.
Fhat GS 300 Sport. Talbot Autosleeper with LPG.
If you ain't got 8, you ain't got enough.</font id="blue"></b>
Who is the randy Reindeer?
Postby TR Tony » 09 Nov 2007 11:19
That explains why Brake parts Online list 2 different discs, & one of them is indeed described as Celica Supra - that'll be the one then!
John - these Supra discs are listed as 20mm thickness. What did the Vitesse use - solid discs? Shame that a spacer is needed, scuppers my little plan for a cheap upgrade!
Postby bmcecosse » 10 Nov 2007 18:17
WIKI = Wikipedia see here http://en.wikipedia.org/wiki/Wiki
