Halogen lamp upgrade.
Tack
Postby Tack » 31 Mar 2012 13:32
Thanks Craig
It finally hit me about 3 am. I'll plug the blue/brown/white plug into the right side original headlamp plug and just feed the rest. I guess the worst part of the job will be taking off the plugs and the putting them back on after feeding wires through those tiny, dirty holes.
Randy
quote]<i>Originally posted by trekcarbonboy</i>
I used the VB harness and it works great. The trick to installing it is to remove the 3 wires from the headlamp plugs and feed them through the light pods and then re-install and hook-up to the lights. You have to remove the factory plugs the same way then just hook the passenger side plug into the new harness and the drivers side factory plug just gets tucked up behind the horn.
No splicing required!!!
Craig '75 2.0 FHC
[/quote]
1980 TR7 DHC pageant blue
trekcarbonboy
Postby trekcarbonboy » 31 Mar 2012 15:41
Just use a small sliver of something to depress the little spring catch that holds the metal connectors in the plastic plug and they slide right out.
Craig '75 2.0 FHC
Users browsing this forum: No registered users and 105 guests
