Alternator Problems....
TriumphCMT
Postby TriumphCMT » 11 Aug 2010 01:02
I just bought a reman alternator from victoria british and I ran into a problem...
The connectors to the alternators are different.[V]
As you can see with the picture below, the prongs to the new one has a small, big, big pattern of prongs.
The old one has small, big, small pattern to it.
The new one also has two additional connectors on it. The bolt with 2 nuts and another prong.
I did make sure to order the right alternator form the catalog. (1979 TR7 w/ A/C, Part# 8-125-Z)
^^The connector^^
^^Reman Alternator^^
^^Old Alternator^^
^^Old Alternator with cover on it^^
^^Both Alternator^^
- Chris
TriumphCMT
Postby TriumphCMT » 11 Aug 2010 01:05
Does anybody know how I can fix this or should I just return it and rebuild the one I have???????????
Bobbieslandy
Postby Bobbieslandy » 11 Aug 2010 01:27
I know for a fact you can buy a replacement alternator which bolts stright in, it might be an idea to phone VB up first and ask why you are not able to do so. Hear them out, if they have a valid reason then all's good, if not, return the alternator and get them (or another supplier) to find an alternative. It would be a shame to have to butcher your cars loom for the sake of a wrong part.
Good luck Chris.
Postby John Clancy » 11 Aug 2010 07:42
Perhaps a previous owner had modified the connector on your car. If that's the case it may be better to put it back to standard.
Postby andyf » 11 Aug 2010 08:03
I believe you may be right John, because from memory I thought the standard Lucas unit had 2 large and 1 small connector as per the new unit, although I am not near my car to check.
1980 Persian Aqua DHC
Postby FI Spyder » 11 Aug 2010 16:12
Here's a picture of my Spider. The wires are separate (no block). However I think my '79 Yellow TCT has a block similar to CMT's but not near car so can't check. The Alternator seems very different from those I've seen and you'll notice it actually has 4 connector tabs.
Postby bmcecosse » 11 Aug 2010 20:25
The Lucas ACR alternators have 2 X large and 1 X small connection. Often only 1 of the large connectors is used - they are both the same bus connection anyway. The 'replacement' alternator you have is very different - I would send it back. If the ACR is not working - it's very often just the brushes - easily and cheaply renewed.
Image Image ImageImage
TriumphCMT
Postby TriumphCMT » 13 Aug 2010 17:11
Thanks for all the advice guys. I just decided to send it back and rebuild the one I have. I think I just ordered the wrong one...[xx(][xx(][xx(]
I talked to the VB guys and they didn't have a clue what the problem was...
I'm guessing I should of ordered the 17 ACR instead of the 20 or 25 ACR.
I just got confused and just saw heater models only and A/C models only.
- Chris
edforrest
Postby edforrest » 14 Aug 2010 11:58
<font face="Arial Black"><font face="Lucida Console"><font face="Century Gothic">Cure your alternator problems foever. Change over to a "one wire". We have an excellent source who can do this for about what you paid for a "new one" at VB. Sure, it isn't Lucas...but isn't that the whole point?? ~!!~</font id="Century Gothic"></font id="Lucida Console"></font id="Arial Black">
ed
Users browsing this forum: Google [Bot] and 113 guests
