Been thinking bout this topic lately, so I thought Id start....
..All us Wedgies with the Z-Strom's, how often do You top up your ZS carb's with damper oil? (I use the same Castrol 20w50 that I use in the engine). This is my first TR7 Ive driven in some years (with stock 2.0L & Z.S.), my last couple wedges were TR8's with Holly/Edelbrock 4bbl upgrade. So that means I can not remember how often I needed to top the damper oil up on my past 7's.
This 7 I am driving now, seems to need damper oil-topping every hundred miles or so to run and idle nicely. (And no, my rubber diaphram's are fine, no tears or weak spots)
So in short....How often do You top up your damper oil? Just something I have been curious about [:D]
