Rear Arm Bump Stops
Rear Arm Bump Stops
Postby RUDDY » 29 Mar 2010 15:23
On the brackets that bolt to the axle (5 speed) there are little rubber bump stops that resist the rear arms, where can these be bought, can't see the part on the Rimmers diagram, or is it just a case of fitting a generic rubber grommet ?
Cheers, Paul
Postby gaz » 29 Mar 2010 15:38
rear bumpstops S&S have them about a fiver each I think plus the dreaded
ukc6729 rear bump stop (late)
http://www.rimmerbros.co.uk/Item--i-GRID006180
Postby gaz » 29 Mar 2010 15:47
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by gaz</i>
thats if you mean these ones:
Postby Underdog » 29 Mar 2010 16:17
I believe Ted (TSI) offers those in urethane. Of course the shipping.
Jim Underwood
tr7jim
Postby tr7jim » 29 Mar 2010 17:32
Paul,
S&S sell the original black rubbers ones and most likely the poly ones if not. Robsport sell the poly ones save you paying for shipping cost from across the pond.
Jim
Postby RUDDY » 29 Mar 2010 18:37
Cheers guys.
Postby Beans » 29 Mar 2010 19:58
Bump stops from Super Pro ...
Postby RUDDY » 31 Mar 2010 12:32
[quote]<i>Originally posted by gaz</i>
Just got a pair of these, wrong ones, although I will use them at a later date, these are the ones that fit in the chassis leg to stop the upward movement of the arm, the ones I am after are the red ones in Beans picture.
So a quick call to Robsport and a pair on the way.
Cheers, Paul
Postby Odd » 31 Mar 2010 14:10
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Bump stops from Super Pro ...
Image <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Beans,
what's with the square washer under the red 'button'?
On mine there is a huge hole in that position..:
The Old One
Postby The Old One » 31 Mar 2010 14:19
Are the brackets still available?
If so from where?
Postby Beans » 31 Mar 2010 19:00
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Odd</i>
... what's with the square washer under the red 'button'? ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That's part of the bracket, it's welded onto it.
All brackets I have lying around have these.
Postby RUDDY » 31 Mar 2010 21:06
There are also two types of bracket, one has a large hole to accept the bump stop and one has a very small hole, my car strangely had one of each , the new poly bump stops only fit the larger hole.
I think Robsport have the brackets cos he asked me if I neede them, I would think they are easily made.
Cheers, Paul
Postby RUDDY » 01 Apr 2010 08:06
Been asked to point out that I did not order the bump stops that came wrong from S&S, I simply ordered the part number quoted from the Rimmers website.
I hope no-one read into the above thread that S&S had supplied the wrong part.
Postby Beans » 01 Apr 2010 21:07
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RUDDY</i>
... I hope no-one read into the above thread that S&S had supplied the wrong part .... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Don't worry I am illiterate [:D]
Users browsing this forum: No registered users and 663 guests
