Hazard Warning Switch
suevaughan
Postby suevaughan » 16 Feb 2010 10:18
Hi all, newbie on here but had my TR7 for 18 years and the hazard warning switch has become so corroded it wont work and MOT now not possible. HELP[:(]
Does anyone have one for sale or know of a second hand/new one. No joy with Rimmers.
Sue
Marko
Postby Marko » 16 Feb 2010 10:43
take it out, disassemble it , clean the contacts and put it back together. it should work if the plastic bits aren't broken.
Postby Beans » 16 Feb 2010 11:07
As Marko stated a good clean will do ...
To illustrate this, piccie of one a the switches before ...
and after cleaning ...
Postby TR Tony » 16 Feb 2010 11:10
Sue, try S&S or Robsport, both have a good selection of new used spares, I am sure one of them can help!
In the unlikely event they cannot help then there are two for sale currently on Ebay Motors (USA) - item numbers 150414654466 or 250536133516. I don't think there are any differences between the US & UK spec hazard switches.
TR8 FHC EFI Factory development car Inca Yellow</font id="size1">
suevaughan
Postby suevaughan » 16 Feb 2010 11:56
Thanks so much for all your help guys, have managed to source one from S and S preparations, Rick was really helpful, should get through the MOT now and back on the road for spring! [:)]
Sue
Postby Maxwell » 17 Feb 2010 00:29
Hi Sue... and welcome!
A bit of background info on your car \ whereabouts would be nice!
Are you in the South-East?
Maxwell [:D]
Postby FI Spyder » 17 Feb 2010 18:57
Beans... that looked like my main switch but you left some corrosion on the case...I can't believe you did that.[:D]
You don't have to buy a new switch, you can clean the old one for free using some Brasso or the like. But take pictures as you take it apart as it goes back several ways. I didn't and had to spend some time figurig out which contacts where N/O and which where N/C from the wiring diagram.
Postby Beans » 17 Feb 2010 19:08
Beans ... you left some corrosion on the case...I can't believe you did that ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Please accept my Humble excuses for this sloppy work [:p]
