gearbox oil
Postby bmcecosse » 03 Oct 2009 18:32
Mine is on EP75/80 - as per manual. Yes - the first change from 1st to 2nd in the morning has to be done slowly - after that - it's fine!
Image Image ImageImage
Postby saabfast » 03 Oct 2009 19:54
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by harvey</i>
[quote][i]so use Dexron II ATF to spec M2C 33G (by Comma) as in the Handbook. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Dexron II can't meet M2C-33G spec because that spec is specifically NOT Dexron type. I wouldn't use Dexron type fluids because they have friction modifiers in them which could affect the operation of the synchros. M2C-33G however doesn't have the modifiers in it, and doesn't get as thin when hot as the Dexron does, and that is what I have always used, and will continue to do so.
I will have to check what is in the garage (a few miles away). Stand corrected if it is not DII, I know I looked for the stated spec. (May be stated in error as I use DII in the Saab).
Saab 9000 Stg 1
Saab 9000 2.3 FPT Auto
macmattom
Postby macmattom » 03 Oct 2009 20:08
<font face="Comic Sans MS"><font size="2"><font color="blue">So would any ATF do, or is there a prefferred choice? I'm leaning towards the Castrol SMX-S as I've seen that around, but is that a decent ATF? If not, what is good but, importantly, readily available?
I know opinions will vary, but they also help those of us new to the game make our own minds up.
Cheers,
Mac.</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby Beans » 04 Oct 2009 11:57
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by macmattom</i>
<font face="Comic Sans MS"><font size="2"><font color="blue">... I'm leaning towards the Castrol SMX-S as I've seen that around, but is that a decent ATF? </font id="blue"></font id="size2"></font id="Comic Sans MS"><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
It's definately not an ATF and I recommend it [:)]
http://tr7beans.blogspot.com/2007/08/more-10cr-preparations.html
Postby saabfast » 04 Oct 2009 13:53
I stand corrected, the oil I use is Comma AQF (not Dexron II). It is to the (Ford) spec M2C-33G. I have not had a problem and it is only about £15 for 5 litres from the local factor.
Saab 9000 Stg 1
mitchelltjohn
Postby mitchelltjohn » 05 Oct 2009 00:06
I listened to all the Castrol SMX-S recommendations on this forum and drained perfectly good ATF to fill with the expensive synthetic. And my expereince: SMX-S is definitely worse at cold, 2nd almost impossible to select. Slightly better 2nd grear selection when warm but that wasn't a problem I was trying to solve. Also I can't be sure, but I not happy with the sound coming from my tranmission over 70mph. If I could be bothered I'll be changing back to ATF and someone else have have 2liters of barely used SMX-S to play with!!
standard 1981 DHC
harvey
Postby harvey » 05 Oct 2009 15:07
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by saabfast</i>
I stand corrected, the oil I use is Comma AQF (not Dexron II). It is to the (Ford) spec M2C-33G. I have not had a problem and it is only about £15 for 5 litres from the local factor.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
M2C-33G spec. fluid is also the only one to use if you have a car fitted with a BW65
