Brownish backfire
Johnluss
Brownish backfire
Postby Johnluss » 21 Sep 2009 02:08
My Fergie had problems today. This morning going for a ride my friend noticed that on a few short period there was some brownish smoke coming out of the exhaust pipe. Later going downhill in a winding road, mostly on compression, there was a big backfire leaving behind a cloud of brownish smoke again. I am surprised the muffler is still in one piece. The rest of the day everything went smooth.
Pls all doctors tell me what is the problem with her.
Thanks
Postby jclay (RIP 2018) » 21 Sep 2009 02:21
Is there an air pump installed and have you fixed any vacuum leaks lately?
The air pump can cause backfires when you let off the gas.
Johnluss
Postby Johnluss » 22 Sep 2009 00:11
I have removed the air pump a few years ago and no ajustment made or air leak fixed lately.
Thanks
Postby jclay (RIP 2018) » 22 Sep 2009 00:28
OK, I would look for an air leak around the exhaust header and do a compression check for a burnt valve.
Postby Hasbeen » 22 Sep 2009 03:10
Yep, air leaks into the exhaust will do it, so have a good look for
one.
So to will unburnt fuel in the exhaust, so do that compression test.
However, a riding, or near riding exhaust valve, will do the same
thing as a burnt valve, so check your valve clearances.
A mate of mine who had a 50s Morgan +4, [Vanguard/Fergie/TR 3
engine] used to refer to it as his Fergie in drag. Do you think of
your Fergie as your TR3, in drag? I'm sure it would endear you to
the side curtain brigade, if they were to hear you doing so.
Johnluss
Postby Johnluss » 23 Sep 2009 23:47
Thanks for the tips and I will check that this weekend.
But what worries me most is for a french speaking like me is to understand the last part of your answer. Could you repeat that in plain english?
one.
Postby FI Spyder » 24 Sep 2009 02:27
Don't worry John, he's Australian. We can't understand him on the west coast either.[:D]
Postby PeterTR7V8 » 24 Sep 2009 02:43
As a Kiwi I understood it but I disagreed with it. [:D]
Postby Hasbeen » 25 Sep 2009 08:48
Sorry, it was just a joke, about having a Standard/Triumph engine,
basically the same as the TR2 to TR4, & the same one used in the
Morgan +4, in your tractor.
PS, Any success yet?
H
Postby Beans » 25 Sep 2009 09:46
Still thinking of putting the later Fergie version of that engine (yes the petroleum/diesel one) in a TR2 or TR3.
Of course tegether with the mushroom shaped filter for the cranck case ventilation through the bonnet [:D]
Or a Fergie on Webers ...
Postby PeterTR7V8 » 25 Sep 2009 10:03
I may be wrong but I think "Fergie" is John's name for his TR7 & not the iconic Massey-Fergusson tractor that had the TRiumph engines.
Postby Beans » 25 Sep 2009 10:33
I may be wrong but I think "Fergie" is John's name for his TR7<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If you see the TR7 as a descendant from the old TR's it is also related to the iconic Fergie.
So quite an appropriate name I'd say [:D]
Postby Cobber » 25 Sep 2009 13:01
<font size="2"><font face="Comic Sans MS">When I saw the title of this thread: <i><font color="brown">"Brownish Backfire"</font id="brown"></i>
My immediate thought was to post a suggestion along the lines of, recommending a change in diet or seeing a doctor! [:D] </font id="Comic Sans MS"></font id="size2">
85'Alfa 90, 69'Ford F250.
Johnluss
Postby Johnluss » 26 Sep 2009 02:32
Fergie is the name I gave to my TR7 based on the royal Fergie, we all know I think, with the red head and the special charactar.
But thanks for all your suggestions. Planning to check that this weekend.
Users browsing this forum: No registered users and 96 guests
