Fuel tank supplier
Postby bmcecosse » 14 Jun 2009 19:55
T D Fitchett DO make the tanks for everyone else - and they are the cheapest supplier in my experience. I ordered one by phone - and it arrived next day - great service. I painted it before fitting as I thought the standard paint finish was a bit thin. Would advise you to do the same Steph! I hung it from a garage rafter by a cord - and painted it all around with brushing Hammerite.
Tank out doesn't make any great difference to suspension access - although quite a bit of it has to disconnected - if I was doing this again I would REMOVE the rear axle - rather tha struggle round it hanging down with almost all the bolts out anyway.
It is however a good chance to deal with any rust spots developing - and to spray on lashings of waxoyl.
Image Image ImageImage
Postby busheytrader » 14 Jun 2009 19:56
Jackster,
Have a look at this previous thread for some info.
http://www.forum.triumphtr7.com/topic.asp?TOPIC_ID=9896
Postby tr7inc » 15 Jun 2009 06:37
hi Steph , im very well & Bless , it can be frustrating at times chuck, ive hit my head against the wall many a time, so decided to instead of rushing to get my car on the road for this great summer,i decided to go in my Rover Cabriolet to the different places etc, work permitting of course, one day you will have youre car at a show, and you will feel proud, just like i know i will when i get me there also. Keep smiling talk soon
1979 BL Press Car Pre Production Prototype Inca Yellow DHC
pupinabox
Postby pupinabox » 15 Jun 2009 14:02
Anybody ever heard of this:
http://www.gastankrenu.com/index.htm
They have a dealer in the UK. I was thinking about having them re-do the tank in my 7 as soon as I get up the nerve to try and take it out. Looks like it may be decent. There is a guy a couple hundred miles from me who gave me a phone estimate of around $200.00.
Henk
Postby Henk » 15 Jun 2009 15:58
The price off a new tank.[:)]
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Postby FI Spyder » 15 Jun 2009 17:09
Exactly, fine for those old cars that don't have new tanks available but better to go new tank route if available.
Postby bmcecosse » 16 Jun 2009 15:21
Don't waste time/money on dubious tank sealing - just fit a new one. then you know it will be good for many years to come. Paint it before fitting!
Rblackadar
Postby Rblackadar » 16 Jun 2009 15:59
Most likely, you will have to do a refurbished tank as new ones are not to be found in the US for early models like mine.I've heard RENU has a lifetime warranty and they have been around for a while so I feel better about that. Scott at Team Triumph has them. New tanks for the later models run about $500.00 USD from VB. Then you have to factor in the cost of shipping......I'll take the RENU one when it comes time.
Postby Hasbeen » 16 Jun 2009 23:20
I would have loved a new fuel tank, however, 6 years ago I was
quoted A$800 for a new one, X UK, or A$900 for a locally made alloy
tank. Shipping air, in the form of empty fuel tanks, around the
world, or even Oz, is very expensive is seems.
As there is only so much one can spend on an old car, I repaired the
old one. It's not that hard, if the rust is all internal.
If it is internal, it will be only in a narrow strip, across the
tank, at the bottom front, or it has been in all those I have worked
on, here in Oz. Cutting this out, & replacing with new
metal is much easier than many of the body repairs I see many of you
do on your cars. Some of you do things I can only dream of, so you
could this easily.
Just my two pence worth.
Postby bmcecosse » 17 Jun 2009 11:57
Indeed - if you have the welding skills to make a liquid tight repair - and take the necessary pre-weld precautions of course! - then that's exactly what I would do if the new tank here in the UK had not been quite 'reasonably' priced. I have welded a new base on a rotted/leaky sump (Fiat - not Triumph!) before now - and that worked very well. Morning's work saved over £60 pounds.
Postby john » 17 Jun 2009 12:56
A new tank is going to cost you around £145 + strapes etc another £25
