NUMBER PLATE FITMENT QUESTION
Postby tr7inc » 15 May 2009 19:43
Hi all just a quick question, as im having new number plates to go on my 7, from your own experience, have the majority of you screwed youre plates to the car front and rear , or have you used the adhesive stick pad strips instead?
Many thanks
1979 BL Press Car Pre Production Prototype Inca Yellow DHC
Postby stevie_a » 15 May 2009 20:13
<font color="maroon"><b>I have screws at the front and tape at the back on UK bumpers with over sized plate at the back </b></font id="maroon">
Postby busheytrader » 15 May 2009 20:27
Sticky pads at the back.
Number plate screws and pads similar to these through the plastic front bumber. http://www.halfords.com/webapp/wcs/stor ... lgcb0u_OIF
That's what Grinall's used when they restored the bodywork almost 20 years ago. Haven't fallen off yet.
Postby tr7inc » 15 May 2009 20:35
Cheers guys, i have screws at the front and sticky pads on the back at present, so i think i will do just the same when i put my newer plates on, use i very fine drill bit and use the old plate as the template for the holes.
Postby gaz » 15 May 2009 20:40
i think they originally had a metal frame/back plate on the front with the number plate glued to it i think it was painted black.
Postby gaz » 15 May 2009 20:43
[quote]<i>Originally posted by busheytrader</i>
I also used these but in black when re-fastening my front grill......
Postby TR Tony » 15 May 2009 21:20
My car has the plates mounted by self tapping screws front & back. It has always been that way - I presume the original dealers drilled the two small holes through the back panel.
Once a year I take the rear plate off so I can clean & polish the paintwork behind the plate - & check for signs of rust in the screw holes!
Postby Chris Turner » 15 May 2009 23:13
The suplying dealers put a small piece of plastic tube over the end of the self tapping screws, stop you scratching your hand on the ones in the boot.
www.triumphtrs.co.uk
TR8 FHC
TR7V8 rally car
Postby Beans » 16 May 2009 00:22
...Once a year I take the rear plate off so I can clean & polish the paintwork behind the plate - & check for signs of rust in the screw holes!...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Polisher [:p] [;)]
Postby TR Tony » 16 May 2009 12:46
Polisher [:p] [;)]
My secret is out[:I]
jeffremj
Postby jeffremj » 16 May 2009 14:15
I use screws at the front and sticky pads at the back. I use a metal number plate at the front and perspex at the back. The reason for metal to the front is that when brushing past the front I have snagged against a perspex and it cracked into pieces - the metal just deforms and can be bent back [:)]
The reason for the sticky pads at the rear is that any mounting holes are prone to rust [:(]
